Order Farmall Cub Parts Online
Cub Hydralics (fluid coming around fill plug)
GNB
09-12-2005 18:46:46
My friends cub (48) has a good bit of hydralic fluid coming out around the fill plug even when tight. What is causing this? Plugged Line maybe or plugged passage in the block? Also the lift arms jerk up every now and then but they seem strong when lifting something. Thanks in advance for the input.
GNB
John *.?-!.* cub owner
09-12-2005 19:10:03
 Re: Cub Hydralics (fluid coming around fill plug) in reply to GNB, 09-12-2005 18:46:46
There is supposed to be a copper washer on it for a seal, but from your description my first suggestion would be to drain it and flush it with Hytran and then refill with Hytran. It sounds suspicously like it has the wrong fluid and is foaming.
