B governor repair
donwisc
09-12-2005 18:47:55
Getting most of the issues resolved on my B where she now has some power and response is much better. I still have some flutter in the governer even after adjusting the surge adj screw. The screw is turned in so far that it is now up past the lock nut with no change. looking at the cutaway Im thinking the surge spring may be missing on top of the screw.
My question is Can the the adjusting screw be turned all the way out and will the spring on top , if there is one, come out with it? Or do I have to take the governor off and apart to determine whats up.
The gov response is getting better but its probably due to running the tractor hard with the mower and getting good hot oil thru the system.
I dont have a problem taking the gov off but curious if its possible to make this check.
Farmalldan
09-13-2005 06:09:10
 Re: B governor repair in reply to donwisc, 09-12-2005 18:47:55
Yes, screw, spring and all will come out the bottom. Spring is set into a recess bored in the set screw.
donwisc
09-13-2005 06:37:16
 Re: B governor repair in reply to Farmalldan, 09-13-2005 06:09:10
Thanks Dan, this inspection may eliminate the need to take off the Gov.
donwisc
09-13-2005 10:55:42
 Re: B governor repair in reply to donwisc, 09-13-2005 06:37:16
Well it turned out as expected, the only part of the spring left was down in the recess in the screw, new one on the way from the dealer, should know tomorrow if we got it fixed
