560 IH wiring diagram
BL
09-12-2005 19:36:51
I need a wiring diagram for a 560 IH dsl. Also I need a seat and back rest for a 560 wheatland.
Robhkent
09-13-2005 16:17:19
 Re: 560 IH wiring diagram in reply to BL, 09-12-2005 19:36:51
BL:
I am home now, send me an email and I will return the diagram. Credit Jim
Rob
bermuda ken
09-13-2005 12:12:51
I can fax a diagram of this to you. Let me know your fax number. 1-866-FARMALL (327-6255) 8-5 cst.
Thanks!!
benras
12-02-2006 15:15:07
 Re: 560 IH wiring diagram in reply to bermuda ken, 09-13-2005 12:12:51
I am not able to actually recieve the fax, so have it go to Helen Rasmussen. The fax number is 515-292-3699. Once again thank you. I will be looking forward to getting this problem fixed. Thank you.
Ben Ras
11-12-2006 10:24:36
If you could fax that to me it would help. Just to be clear (6volt to 12volt for a 560). I thank you.
benras
10-28-2006 09:31:59
I am looking for a diagram that will show how to prpperly convert a 560 (gas) from 6 volt to 12 volt. Tried having a friend do it, and it is now burining up the points. I need help if anyone can send me an email with instructions, or a diagram I would be greatful.
Robhkent
09-13-2005 06:52:10
BL:
I had the exact same question about 3 weeks ago. Someone was kind enough to get it for me. I have it at my home machine, if no one else takes care of it by this evening I will post it for you.
Rob
