Re: 3 pt on IH 444 doesn't work
Mark Scholten
09-13-2005 19:00:00
I talked to the owner of the tractor tonight to get some info and history. It appears that he was plowing and the plow jumped up and the 3 point stuck in the raised position. A friend of his took the top casting into the dealer and he replaced some parts but it still doesn't work. There is good pressure and flow but the oil is lost at that point. I am going to pull the on/off control body off and look for a blown "O" ring. He told me to keep it at $400.00. That's where I will stop.
Mark
JB2
09-14-2005 13:41:20
 Re: 3 pt on IH 444 doesn't work in reply to Mark Scholten, 09-13-2005 19:00:00
Hi Mark, usually when the 3pt would jump up to the top it was because the depth control lever was not far enough down to the heavy position.
The other thing to check is the spring behind the top link connection. If this spring breaks or the bolt unscrews then the draft control sensing goes crazy. Make sure the draft control sensor is sticking out of the casting about 3/4".
The draft control sensor is a chrome plated rod that sticks out of the hydraulic casting by the right side of the top link bolt.
Good luck
JB2
Mark Scholten
09-14-2005 14:23:29
 Re: 3 pt on IH 444 doesn't work in reply to JB2, 09-14-2005 13:41:20
The sensing piston? is sticking out about 2 1/2". There is nothing hanging on the 3 point now and it is all the way down. Mark
Mark Scholten
09-14-2005 15:23:13
 Re: 3 pt on IH 444 doesn't work in reply to Mark Scholten, 09-14-2005 14:23:29
To clarify, the owner weas plowing and hit something hard and the plow jumped up. Apparently jamming something or even breaking or distorting something. I checked the draft control rods by the 3rd link and everything seems in order however, with the tractor running, I feel no resistance when I move the casting where the 3rd link hooks up. Shouild I feel some resistance against the verticle piston plunger thingy? It moves about a 1/2" when it comes up against the verticle plunger. I am guessing that the horizantol plunger on the left side is the depth control and that is free and moves in and out with the depth control lever.
Mark
Jb2
09-14-2005 16:59:14
 Re: 3 pt on IH 444 doesn't work in reply to Mark Scholten, 09-14-2005 15:23:13
Hi Mark, from your description draft control sensing would appear OK. So all the simple things have been checked. I would check the archives as about a year ago someone had a problem with a B275 or B414 hydraulic system and he went into great detial on the repair.
Please let us know the fix.
Good luck
JB2
Mark Scholten
09-14-2005 18:48:10
 Re: 3 pt on IH 444 doesn't work in reply to Jb2, 09-14-2005 16:59:14
I will let you know what I find out although I have checked the archives I found nothing of help. Thanks for your help so far.
Mark
