1586 air and cab contols
jim mallan
09-14-2005 17:30:13
on my 1586 the air radio wipers and fan quit working are these controled by the key switch or something else. please help jim
Ia Gary
09-15-2005 05:26:57
 Re: 1586 air and cab contols in reply to jim mallan, 09-14-2005 17:30:13
Had this happen many times on my 1086's. Can be relay behind kick plate like others said or can be key switch also. I have had to replace both.
the tractor vet
09-14-2005 18:35:56
There is a CV relay down in the kick panel down under the steering wheel below the dash , looks like a starter selionid on a ford . Use a testlite and see if ya have juice on both sides of the big posts , if you only have juice on one side with the key on see if you have juice on the small post if no juice there trace back to the key switch . It could be a broken wire or just a termainal that came off or even a bad key switch .
P Backus
09-14-2005 17:51:13
There might be something in the archives about that-I seem to remember.
I would check the ground from the cab frame to the tractor frame. There should be a wire conecting the two, and since they all quit working at the same time..... .
Paul
