Farmall M anti freeze in oil
DWM
09-15-2005 06:56:41
I noticed anti freeze in the oil when I dropped the pan the other day. The engine block seems to holding antifreeze, (going on 2 weeks now), any suggestions on what to check next?
c
09-16-2005 20:58:56
 Re: Farmall M anti freeze in oil in reply to DWM , 09-15-2005 06:56:41
If you have oil pan off look and see if there are any drops of coolant on the bottom of the sleeves. You might have to replace the sleeve o rings.
El Toro
09-15-2005 07:22:28
You should put about 5 lbs air pressure on the radiator and see if you have any leakage from the
bottom of the engine. It may only leak when the engine is warm. Hal
dwm
09-15-2005 07:57:06
 Re: Farmall M anti freeze in oil in reply to El Toro, 09-15-2005 07:22:28
Hal, I took the head off and its being checked for problems. The head gasket showed signs of blow by, blacken areas near the pistons on the head gasket. Think that might be the culprit?
El Toro
09-15-2005 12:28:52
 Re: Farmall M anti freeze in oil in reply to dwm, 09-15-2005 07:57:06
I would have the head checked to see if needs to be milled, could be warped some. Hal
