FARMALL M
jefft
09-15-2005 16:46:35
I have a 1944 FARMALL M that runs fine at idle or lower speeds but won't pull a load.it sputters and wants to die.does anyone have any ideas I would appreciate the help.thank you
JT
09-15-2005 17:00:00
 Re: FARMALL M in reply to jefft, 09-15-2005 16:46:35
Have you checked your plugs, and plug wires, if they are original, they probably need replaced. How many turns do you have your high speed jet turned out?? should be at least 3-3.5 turns.
Yugrotcart
09-15-2005 16:54:35
Did you try adjusting your main jet? Either that or maybe a plugged sediment bowel screen, or fuel filter, only letting a limited amount of fuel through.
