bahlen power steering
hardcase
09-15-2005 20:02:39
Can anyone help with the plumping on one of these motors it"s on a Farmall 400 and when I use the loader it robbs all the Hyd fuild and is hard to steer shouldn"t there be a priority valve in the system? Thanks Hardcase
Illinois Boy
09-16-2005 07:33:53
 Re: bahlen power steering in reply to hardcase, 09-15-2005 20:02:39
The Behlen unit runs off the same pump / resevoir as the hyd system. The pressure valve / by pass setup is under the cowl on the opposite side of the valve gang. (usually dist side) and is part of the resevoir - valve gang, opposite the valves.
You"d better get a shop manual if you"re going to tear into it - lots of little pieces. (Don"t ask how I know this...)
