M 300 carb
Dick Davis
09-16-2005 03:51:48
Does the 300 Farmall use a straight M carburetor? Thanks for any ino, Dick Davis
MikeF
09-16-2005 19:16:34
 Re: M 300 carb in reply to Dick Davis, 09-16-2005 03:51:48
We have a 300 that blew up a few years back and we put an H engine in it with the crater pistons. We put the 300 carb on the H engine and it made it run better, but an M carb is bigger
DWV
09-16-2005 05:38:34
Other than carb # on tag main differance you see looking at them is 300 has choke lever on engine side and the idle air adjust screw in different place.Inside the 300 has a smaller venture and different fuel mettering.
Van in AR
09-16-2005 04:57:12
300 and H basically use the same size carb, the M uses a larger carb, Same as a W-6 and U-6 power units.
Van
Andy Martin
09-16-2005 10:24:46
 Re: M 300 carb in reply to Van in AR, 09-16-2005 04:57:12
The Super H and 300 are about the same, and the Super H has about the same carburetor as the M and Super M.
RustyFarmall
09-16-2005 04:30:45
I believe the carbs will interchange, but I do not know if there are any differences inside the carbs. The 300 carb may have a smaller main jet, or maybe not. I would think the differences would be very slight.
