IH 240 points gap
Dean Wheeler
09-16-2005 06:12:32
I have an IH240u with points that need replaced. I pulled them without measuring the gap (yes I now realize that wasn't wise). This tractor has been converted to 12 volt (still positive ground) but doesn't have a magneto. Does this change the gap I need to set the points at? Or can I still use the gap provided by my manual? If I'm reading the manual correctly, this tractor originally came with a magneto. Thanks
Red Dave
09-16-2005 06:37:58
 Re: IH 240 points gap in reply to Dean Wheeler, 09-16-2005 06:12:32
I've never worked on a 240U, but just about all the other IH's with battery ignition I've worked on have specified .020 points gap.
If that isn't correct, I hope somebody will step in with the right gap, but if it were mine, I wouldn't be afraid to set them at that until/unless I had reliable information to the contrary.
Coax
09-16-2005 18:31:55
 Re: IH 240 points gap in reply to Red Dave, 09-16-2005 06:37:58
I"ve got one and Your right....020 at least if you have a Dist.
