Difference between 49 50 M
fishermanS
09-16-2005 09:37:06
I am just starting to learn about tractors and have a working 49 M and non working 50 M. The breaks on the two tractors differ. The 49 M has a much larger Break cover than the 50 M.
Can anyone explain or expand on this. One is a 180000 serial number and the other is a 222000 serial number if that helps. Thank you in advance.
RustyFarmall
09-16-2005 13:25:19
 Re: Difference between 49 50 M in reply to fishermanS, 09-16-2005 09:37:06
One of them may have the aftermarket "Lambert" disc brakes.
DWV
09-16-2005 10:24:55
Brakes on 49 and 50 were same.One may have disc
brakes installed later, or if only left side of
tractor is bigger you may be looking at cover for
aftermarket hand clutch.
Yugrotcart
09-16-2005 12:41:15
 Re: Difference between 49 50 M in reply to DWV, 09-16-2005 10:24:55
Sounds like a MW clutch one the one tractor.
