Order Farmall Cub Parts Online
CUB, Hydraulic unit leaking fluid into motor?
Josh Hoffman
09-16-2005 11:19:07
I've got a 1951 Cub. I just finished a transmission rebuild, put it all back together, painted it...& now, my hydraulics are leaking fluid into my motor if I leave the implement on my hitch down (I use it to York rake)...it doesn't seem to leak if I leave the rake "up"...The fluid in the hydraulic unit actually seems to drain into the motor because the hydraulic fluid will get low & motor oil level will rise? Anyone ever heard of this before? Will the hy-trans fluid do any damage to my motor (I drain it out as needed/ check it before every use)? Thanks from the coast of Maine.
Rudi
09-17-2005 06:17:27
 Re: CUB, Hydraulic unit leaking fluid into motor? in reply to Josh Hoffman, 09-16-2005 11:19:07
Josh:
CNKS provided interesting info and the principles are similar.
BigDog gave you the correct diagnosis.
As was mentioned before -- the overhaul instructions along with the ordering kit info is available on the Cub Manual Server....
Consider the horse led.....
Bigdog
09-16-2005 14:34:39
The pump needs new seals (O-rings). This is a classic sign.
CNKS
09-16-2005 11:56:43
Read the F 130 hyd pump leak post below -- principle is the same.
