660 diesel
Jake E.
09-16-2005 18:10:46
I have two questions about a 660 diesel. First, I was wondering if anyone knows the head bolt torque specs. Also the PTO will slip when it is under load, is there any adjustment or part to look at replacing.
Thank you
Billde
09-17-2005 05:29:26
 Re: 660 diesel in reply to Jake E., 09-16-2005 18:10:46
Head bolts 115 ft/lbs. there is an early type and a late type. I remember the early ones the unit had to be removed from the tractor. The later style could be adjusted with the unit on the tractor. You realy need a service manual to made the adjustments.
