H - Gas Tank Removal
Elk Farmer
09-17-2005 13:05:10
I see there are three bolts with nuts and springs that hold the tank on. When I try to remove the nuts the stud turns. Am I in danger of getting a leak. What is the best way to remove the tank?
Thanks for your help
Elk Farmer
Bob Frey
09-17-2005 14:34:05
 Re: H - Gas Tank Removal in reply to Elk Farmer, 09-17-2005 13:05:10
You're doing it right. The nuts can come off or the studs can come out. Either way is ok.
Bob
Elk Farmer
09-18-2005 04:54:58
 Re: H - Gas Tank Removal in reply to Bob Frey, 09-17-2005 14:34:05
Thanks Bob,
Elk Farmer
