Hey Farmall H Pros
MikeF
09-17-2005 19:05:01
I just got a 52' H and I would like to know if any of them had super H engines in or something else. I am asking this because my H is definitly not a stock H. Also is it possible for it to have a high speed 4th like a 300.
earlschieb
09-18-2005 06:34:04
 Re: Hey Farmall H Pros in reply to MikeF, 09-17-2005 19:05:01
Is the serial number suffix X1F ? That is what my 51 model is, and it will flat run off and leave a 54 stage II Super H, in 4th gear.
RustyFarmall
09-18-2005 04:32:24
There was an optional dealer installed 7 mph 4th gear. Might be what yours has.
Nat
09-17-2005 22:50:39
Since the bolt patterns were the same, any H, Super H, 300, or 350 engine could easily be bolted in at any time during the tractor's life. It didn't have to come from the factory that way... Same goes for the transmission. You could put Super gears in very easily during a rebuild.
The engine's displacement is stamped into the block. It should be C-something.
There was also an "overbore" kit for rebuilding the engine. Wasn't the same as a Super H because the Super's block was bored out for larger sleeves, but it did the job.
THEkyroastnear
09-17-2005 21:43:25
i recall your post from few days back didnt you say it had a fresh overhaul a year or two ago but been sitting? that the gent who did the work had passed on. it is possible he rebuilt using a super kit(pistons sleeves ect.) a lot of farmers did this after the supers came on the market to increase h.p. dont know about a fast 4 th some had a fast 5th some have 9 speeds those are aftermarket from M&W or heiseler im definitely not a authority maybe some with more knowledge will post
MikeF
09-19-2005 19:13:44
 Re: Hey Farmall H Pros in reply to THEkyroastnear, 09-17-2005 21:43:25
I didn't here him right it's been sitting for 5 years and the guy is still around. It was a fresh engine, but he can't remember if he had anything done to it or not. Thanks everyone for the replys
