Brake Sticking on H
Triker
09-17-2005 19:41:08
Can someone help me on a sticking brake. The left brake works great and stops with no issues. The right brake, when you push down on the pedal, does not grab and doesnt return to the original position. It sticks and I have to take my hand to return it. Does anyone know how I can fix this? Thanks.
Nat
09-17-2005 22:44:27
 Re: Brake Sticking on H in reply to Triker, 09-17-2005 19:41:08
Take it apart, clean it up, put it back together. You may also need to replace the brake band and/or other internal parts that may be broken or badly worn. It's not that complicated or difficult. I'm confident you can do it, and I don't know you from Adam. That should tell you how easy it is...
