Hydraulic Supply for Front End Loader on I2400A
JD233
09-17-2005 21:03:38
Purchased International I2400A Utility tractor. Has had a front end loader mounted. Needing to know were to hook up the hydraulic lines from the two open-center type auxiliary valves mounted on the right side of tractor to supply fluid for front end loader? Appears that the previous loader was factory installed. No signs of a external pump was assembled to the tractor.
Thanks,
JD
Nat
09-17-2005 22:41:41
 Re: Hydraulic Supply for Front End Loader on I2400 in reply to JD233, 09-17-2005 21:03:38
There should be two pairs of hydraulic outlets connected to those valves by way of hard or flexible hydraulic lines. The lines may be capped off, or they may have quick-connects on them.
You're going to have to hunker down and take a good look at the tractor. Don't glance at all the hoses and lines, throw up your hands and say, "It's too hard!" If that's your attitude, sell the tractor now. You'll be way farther ahead...
