need more power from my 706
706 puller
09-18-2005 09:39:07
I have a stock 706 gas 263ci. It makes 70hp. What can I do to make more power, and how can I get more RPMs. Is there anything I could change with the carb, head, cam or valves. I pull in a 9500lb farm stock class against tractors that are not stock, so I need to find an edge.
dixie doodler
09-18-2005 14:55:29
 Re: need more power from my 706 in reply to 706 puller, 09-18-2005 09:39:07
You can change this tractor over to a 301 out of a combine, that engine has 105 HP., if you want to stay with a gas engine. You will have to put the front cover and flywheel off this tractor on the 301
