Toy Tractor ID
Fawteen
09-18-2005 13:58:05
third party image
Which actual tractor does this toy most closely resemble? I'm planning to repair/restore/customize it, and would like to get the details as correct as reasonably possible. It's a 1/16th scale ERTL, and what's left of the decal on the front edge of the cab roof says "Magnum".
Seeing as it's newer than a Super M, I'm pretty much clueless...
Redfan
09-19-2005 01:55:01
 Re: Toy Tractor ID in reply to Fawteen, 09-18-2005 13:58:05
Now 14, has the grandson been taking that one up into the hills too? LOL.
JJK
09-18-2005 14:23:34
The picture isn't real clear to get some of the details but it looks like it could be a 7110 or 7120 Case IH Magnum but it could be a 7210 or 7220 cause the cab filter housing on the back of the cab roof is red and not black like the earlier Magnums were. I'm guessing it would be a smaller Magnum cause the front axle looks like a two wheel drive and not a MFD model. I think Ertl made the bigger models with MFD only but I could be wrong. The possibilities could be anything else in the 7100, 7200, and 8900 series tractors. Hope this helps you out and I would like to see a picture of it after you get it fixed up what ever way you do it.
Fawteen
09-18-2005 14:48:10
 Re: Toy Tractor ID in reply to JJK, 09-18-2005 14:23:34
Thanks, that'll help a lot. I can look up pictures of the full-size versions of the models you listed and see which comes the closest.
It's definitely 2WD. I'm planning to dual it up and put high-floatation tires/wheels on the front.
If it comes out any kind of decent at all, I'll post some pix. Likely be a while, as I've decided that tractor and a couple of diecast trucks I have are my "winter project".
JJK
09-18-2005 14:59:37
 Re: Toy Tractor ID in reply to Fawteen, 09-18-2005 14:48:10
If I'm not mistaken they had 4 rib tires on these so they could be like the floaters that you want to put on. Unless you have something different in mind. Fixing and modifying toys seems like a good winter hoby, mine is drawing after work when I feel like it. Lately my drawings have been nice lookin gals and since I'm single I see nothing wrong with it.
Fawteen
09-18-2005 15:10:04
 Re: Toy Tractor ID in reply to JJK, 09-18-2005 14:59:37
I Googled up some pix of 7110's, and it definitely looks like that's the one. Only pic of a 7210 I could find in 2WD was too small, but looked essentially the same.
Got good right and left side shots, so that gives me pretty much all I need to go on. They both had pretty big tires on the front, so the floaters will be a reasonable mod.
Thanks for the help!
