Brush Hog Size - Farmall A
HAS
09-18-2005 19:59:08
What would anyone recommend for the maximum brush hog size that a Farmall A could swing? I'd be mostly mowing large tall stalky weeds, not johnson grass.
John London Tx
09-20-2005 14:26:18
 Re: Brush Hog Size - Farmall A in reply to HAS, 09-18-2005 19:59:08
Don't want to give any info that may cause You to overload Your machine, but my neighbor to the South pulls a 6ft Woods mower all mowing season, and has used the same little model B tractor for 35 years. I pull a 6 ft Mohawk with an H and cut in 4th gear and never have any problems. Just keep the blades sharp and there should be no problems with 6 ft or smaller shredders. Another factor would be density of the vegetation where You are working-We get far less rain in this part of the country and don't have problems with moisture content in the weeds/grass gumming up the shredder-Good Luck
scotty
09-19-2005 04:44:57
HAS, It will run a 4ft rotary mower without much problem. Some fellas have even used a 5ft if only mowing field grass and if not too high with no hills.
scotty
muley
09-19-2005 06:02:21
 Re: Brush Hog Size - Farmall A in reply to scotty, 09-19-2005 04:44:57
My Super A will pull a 5' brushhog through most anything.
