Can an 806 pull an 18ft field cultivator?
MichaelNEIowa
09-18-2005 22:48:50
I've got an 806 diesel. Can it handle an 18 ft field cultivator?
Fella has an IH 45 field cult for sale and is asking $850. Is this a good price?
What should I watch out for?
Billde
09-19-2005 14:57:12
 Re: Can an 806 pull an 18ft field cultivator? in reply to MichaelNEIowa, 09-18-2005 22:48:50
Your 806 will play with an 18 footer, assuming you are running duals. If you are running singles you will get quite a bit of slippage.
Brian Schmidt
09-19-2005 07:47:30
I bought a IH 45 at a sale for a fellow at work. We gave $115 for it. It didn't have much factory paint left on it, but it worked fine and had a cylinder for the lift and harrow out back. He pulls it with his 450. We do have to fold the wings up in heavy soil.
George Johnson
09-19-2005 09:32:33
 Re: Can an 806 pull an 18ft field cultivator? in reply to Brian Schmidt, 09-19-2005 07:47:30
Yes it can. We used to pull a 20 footer with our 806. It pulled it like a champ. It was 3 point mounted and a little heavy but the rock box in the front took care of that problem.
james2
09-19-2005 07:22:15
I sold my 18 ft hydraulic fold IH45 for $150. Shovels needed replacement if covering many acres. Probably sold too cheap, but there isn't any market around here for a smaller field cultivator with limited trash clearance. I tried to pull it one spring with a MM 1050 (dynoed at 118 bhp) in bean stubble, approx 3.5 inches deep, and moved at a snails pace. If you are disking before using the IH45, then no problem pulling it with an 806. Otherwise you will go very slow or just skim the ground. Bought a larger Wilrich which can handle trash much better, and either pull it with the IH 5288 or the IH 4166. Works a lot better!
James2
09-19-2005 08:37:23
 Re: Can an 806 pull an 18ft field cultivator? in reply to james2, 09-19-2005 07:22:15
Realized forgot to mention it also had a 4-bar Remingler spike harrow on back
Allan in NE
09-19-2005 04:34:46
Hi Michael,
Boy! I think that is one heck of a good price!
Your tractor can handle that implement very easily.
Allan
third party image
MichaelNEIowa
09-19-2005 10:02:52
 Re: Can an 806 pull an 18ft field cultivator? in reply to Allan in NE, 09-19-2005 04:34:46
How do you like your vibrashank so far?
Any helpful hints to pass along to a cityboy-farmer wannabe?
Hugh MacKay
09-19-2005 00:36:05
Michael: There is really only two items to watch for; wear in the pivot points of each shank. If the pivot holes are enlarged those parts are quite expensive. The other item you watch for is twisted frame. I saw this once and cultivator cut deeper on one side than the other. They had sprung the lift mechanism towing behind a pickup in transport position.
I personally would look for an S tine cultivator. I bought both new in my farming days. S tine is a much better cultivator and a lot less on repairs. Vibra shanks probably cost $35. each while S shanks are under $10. You will break more Vibra shanks than S shanks.
MichaelNEIowa
09-19-2005 09:57:12
 Re: Can an 806 pull an 18ft field cultivator? in reply to Hugh MacKay, 09-19-2005 00:36:05
Okay, another dumb question. What is the pivot point?
Also, if I buy this, I'll tow it home with my pickup. Any helpful hints in this area (e.g., how to avoid a sprung lift mechanism)?
IHC Red
09-22-2005 19:52:42
 Re: Can an 806 pull an 18ft field cultivator? in reply to MichaelNEIowa, 09-19-2005 09:57:12
It's the horizontal bolt on which the shank trips (pivots) if it hits a rock. The spring holds the other end of the shank tight against the stop. If you follow the shank up from the ground, it attaches to a casting. The pivot point will go through this casting crossways.
On this model, it's a 1/2" bolt. There's a bushing inside. If you pull the shank sideways with your hands, the bolt shouldn't move much at these points. If it does, it has seen a lot of use and will need some parts to fix.
Unless you have really heavy clay, your 806 will work well with an 18' in 4L or 1H. We pulled a 21' with ours in 1H.
McDiesel
09-18-2005 23:26:04
Michael I pull a 21 foot field cultivator with my 806. It has a turbo, I run in high 1 with the TA forward. That is a buy on the field cultivator. Where in NE Iowa are you from? I am from NE Iowa.
MichaelNEIowa
09-18-2005 23:27:49
 Re: Can an 806 pull an 18ft field cultivator? in reply to McDiesel, 09-18-2005 23:26:04
I'm over in clayton county. How 'bout you?
Anything to watch for when buying a used cult?
McDiesel
09-20-2005 00:13:40
 Re: Can an 806 pull an 18ft field cultivator? in reply to MichaelNEIowa, 09-18-2005 23:27:49
Michael I am from Sumner wich is in Bremer county. Did you get some rough weather last night? We got 1 inch of rain.
