Which front with loader
JF in OR
09-19-2005 08:28:56
I picked up a M with a horn loader at an auction saturday for $900. My question is which front end would be better to use, wide or tricycle? Thanks, Jeff
Nat
09-19-2005 09:02:09
 Re: Which front with loader in reply to JF in OR, 09-19-2005 08:28:56
If it's one of those straight-arm loaders that pivots off the rear axle, a wide front won't work. The loader will hit the axle tube before it can lower all the way to the ground.
The bucket width is also a factor. Some of these old loaders have bucket that are barely 3 feet wide, if that. You can't get near anything with a wide front end with a bucket like that.
Otherwise, a wide front does offer a little more stability and strength for loader work.
JF in OR
09-19-2005 11:49:06
 Re: Which front with loader in reply to Nat, 09-19-2005 09:02:09
Its a curved arm loader, the tractor already has a wide front. I thought maybe the tricyle would be stronger and maybe easier to steer.
