Order Farmall Cub Parts Online
Cub pitman clamp
matt in pa
09-19-2005 10:12:58
Hello.
Anyone know how to rig the pitman clamp on the end of the arm nearest the cutter? I understand that there is supposed to be some kind of spring mechanism in between the two pitman straps for clamping onto the ball end of the cutter. Unfortunately, I do not have the spring and the other piece. Can I run a bolt with a spring through the two straps, or can I still get the right parts from Case? If they are available, does anyone know the cost?
Thanks,
Matt
old
09-19-2005 10:25:17
 Re: Cub pitman clamp in reply to matt in pa, 09-19-2005 10:12:58
I use a bolt and washers all the time on them, not the right way to do it but it works. I also double nut the bolt or it will work loose and then it can be big problems
