IH W600 diesel questions??
dtsmith121
09-19-2005 18:23:58
hello guys im an MM man but i found this w600 diesel today for sale and i think id like to own her it is all complete it is stuck but its not from sitting outside it has been in a shed all the sheetmetal is straight needs one rear tire and wheel, it looks to be pretty big like an MM GB i own or so on the right side behind the motor i found a tag im guessing it is the serial number tag and it said #1512 i was wondering if someone could give me some info on the old girl like value, part availability, value when restored, year, horsepower ? thanks or any info you guys have. thanks again
willL
09-22-2005 14:48:15
 Re: IH W600 diesel questions?? in reply to dtsmith121, 09-19-2005 18:23:58
As far as the motor being stuck, if it is a diesel, it is most certainly stuck from having a cracked head and water/antifreeze leaking into one or more cylinders. Good heads are impossible to find and I have never seen a "repaired" one that didn't leak.
Billde
09-19-2005 21:01:46
Just priced sleeves, pistons, bearings, and gaskets for one I was going to buy. Adding hoses and incidentals I came up with 3000.00. That's not including head work. Better buy it real cheap!
P Backus
09-19-2005 19:28:19
Hi, I own a 600D, serial no. 1828. There were only about 1500 of these made total. They were built in 1956 only and were rated at 67 horsepower at the PTO. They elvolved from the W-9 and Super W-9, and the 650 came after them, so there are parts that will work for all of those, like your wheel rim, but there are differences too. Some parts are easy to come by, while others are near impossible to get (like the verticle stainless trim in the middle of the grill).
Diesels were most common, but gas and LP gas could be had too. Some were equiped with a hand clutch (like some MM"s!), power steering, single or double hydraulics, PTO, belt pulley, etc.
Their value increases because of their rarity, but decreases because of their size, and in your case, the potential expense of a tight motor. The value when restored is never as much as you may have in it, like any other old tractor. A good original in running condition might be $2500 to $4000. Restored, who knows?
It was the biggest wheel tractor made by IH in "56 and I love mine, but it isn"t a "handy" tractor. The engine produces over 500 ft/lbs of torque with 350 c.i.d. so it is great fun to work it and feel the power! Post back if you want me to rattle on more about it.
Paul
TWM
09-19-2005 21:43:26
 Re: IH W600 diesel questions?? in reply to P Backus, 09-19-2005 19:28:19
How do you figure out Ft Lbs of torque with a tractor?
P Backus
09-20-2005 06:24:01
 Re: IH W600 diesel questions?? in reply to TWM, 09-19-2005 21:43:26
That torque figure was one that I read in some original factory literature. I"m not sure how one would determine the torque of an engine without the test equipment that is used for that.
Paul
TWM
09-20-2005 10:25:43
 Re: IH W600 diesel questions?? in reply to P Backus, 09-20-2005 06:24:01
I just thought that was a neat measurement, seeing how i've never heard of them measured like that before.
MD Wa.
09-19-2005 19:26:28
DT. The 600's were purduce in 56&57. Looks like yours is a 57. The diesel had a bore of 4 1/2 and a stroke of 5 1/2. = 350 c.i. Weight 6,500# (shipping weight) Around 54hp at drawber and 62 on the belt pully. Hope this helps. Morgan
P Backus
09-19-2005 19:31:55
 Re: IH W600 diesel questions?? in reply to MD Wa., 09-19-2005 19:26:28
I don"t mean to be contrary, but they were only made in "56. The 650 was out by late "56. They were rated at 67 hp at the belt.
Paul
Dave Grindle
09-19-2005 21:47:55
 Re: IH W600 diesel questions?? in reply to P Backus, 09-19-2005 19:31:55
Paul - 1484 were built in 56 & 32 were built in 57 (sn 1986 & up are 57's) ..... ..in 1956 IH built SWD9 , 600 , & 650
P Backus
09-20-2005 06:31:44
 Re: IH W600 diesel questions?? in reply to Dave Grindle, 09-19-2005 21:47:55
Okay- I"ll stand corrected.
It does seem odd that IH would build the 600 and 650 at the same time when the only differences that I know of were cosmetic. It seems like once they started with 650 production, there would have been no reason to build 600s. Oh well, reasoning doesn"t always apply to what companies do!
Paul
