Belt Pulley for 39H
Triker
09-20-2005 06:28:45
Just curious how the belt pulley works on my H. I dont see any lever for it. It is leaking on the outer wheel where it bolts on and I ghought about draining the oil from it so I dont rub against it getting on and off the tractor. If so where is the drain plug and will I hurt anything if the oil is drained. Oh by the way I finally ordered a owners manual, service manual and parts manual. They should be here this week sometime. Thanks as always!
Nebraska Cowman
09-20-2005 10:39:07
 Re: Belt Pulley for 39H in reply to Triker, 09-20-2005 06:28:45
Triker, ya, some of the "do-hicky" posts are a little humorous but I ain't laughin' at you. You can take the whole belt pulley drive housing off the top of the transmission if you want. Then just make a flat plate to cover the hole.
Slappy
09-20-2005 07:40:53
Triker,
The leak is due to a faulty seal. These are not hard to replace and your HI dealer can still get them. As to draining the oil, the pulley is splash lubricated by the forward transmission gears - so you change the oil in it every time you change transmission oil. The unit is set up to hold a limited amount of oil.
To change the oil in this reservoir and change the leaky seal, you first remove the pulley from the 'wheel' it attaches to. Loosen the bolts (if I remember right 4 of them) on the face of the drive unit and pull the shims, bevel gear, shaft, bearing, seal retainer and wheel out as a unit. A fair bit of oil and probably some water will come out as well.
I think (its been a while since I worked on mine) a snap ring holds the works together. If you can avoid it, leave the big Woodruff ket in place. These come out hard and you almost have to destroy them to get them out. They are available but hard to find. If you have to change the bearing, I think the key will have to be removed - maybe yours will come out easier than mine did. I think the seal retainer will come off without removing the key.
I'm sorry I don't remember the exact sequence, but the parts manual and common sense will give you all of the details you need. A relatively easy fix.
The control is a rod that attaches to an arm on the pulley drive unit and exits the ignition switch plate at the base of your steering support shaft - pull the rod to start the pulley.
Triker
09-20-2005 10:36:26
 Re: Belt Pulley for 39H in reply to Slappy, 09-20-2005 07:40:53
Thanks for the explanation. This will help lots.
RustyFarmall
09-20-2005 07:05:56
The belt pulley is located under the gas tank, there is no way it could be leaking oil onto a wheel.
Triker
09-20-2005 09:20:17
 Re: Belt Pulley for 39H in reply to RustyFarmall, 09-20-2005 07:05:56
No, not on the wheel (tire) but the round thingy, I called it a wheel because I dont know better. The outer most part of the belt pulley. Where you bolt the big thingy that the belt goes around. LOL.
wh
09-20-2005 09:52:51
 Re: Belt Pulley for 39H in reply to Triker, 09-20-2005 09:20:17
just remember if you work on it to keep up with where the small ephus goes as opposed to the large ephus, along with the watch-a-me-callit, dohickey, thing-a-ma-bob, and the odd ball shaped thing.
Nat
09-20-2005 09:32:18
You're never gonna make it in this hobby calling things "thingy..." :)
Why are you rubbing on it getting on and off? The belt pulley drive is in front, under the gas tank. Are you climbing on from the front??? Doesn't it seem a little bit difficult to get on and off that way? You're supposed to climb on from the rear...
The "thingy" that the belt goes around is the belt pulley itself.
The "thingy" that the belt pulley bolts to is called a flange, or more correctly, the belt pulley flange.
The "thingy" that is leaking oil is the belt pulley drive, or belt pulley gearbox.
There should be a lever on top of the belt pulley drive that rotates back and forth to put it in gear, and take it out of gear. It's a piece of flat steel, and could be broken off.
Triker
09-20-2005 10:12:20
 Re: Belt Pulley for 39H in reply to Nat, 09-20-2005 09:32:18
Yes, it kinda hard using the front but its just as hard getting on from the back. My 3pt hitch does have a drawbar right now so I dont have an easy way to get on. I was thinking I might look for an step to put on the front of the axle or someplace to make it easier. I bet you guys are out there laughing and saying what kind of newbie bozo do we have here. :-) LOL
SGT K
09-21-2005 03:48:52
 Re: Belt Pulley for 39H in reply to Triker, 09-20-2005 10:12:20
Triker,
At the very least you have a good sense of humor!
Welcome to the club, and good luck.
Paul
Nathan in Texas
09-20-2005 09:17:22
I think he is talking about the "wheel" on belt pulley itself.
