What motor do I have?
Ia |Gary
09-20-2005 14:44:43
I bought a 560 I don't think it has the original motor. The numbers I found on left side of the block are 379875R1.Can anyone tell me what motor this is from that number? Also down lower is no. 8 30 M. Thanks for any information.
ejr-IA.
09-20-2005 19:36:21
 Re: What motor do I have? in reply to Ia |Gary, 09-20-2005 14:44:43
Take a look on the right side up on the front top of the block near where the water pump bolts on block theirs a flat spot it may be stamped 301
IaGary
09-20-2005 20:06:49
 Re: What motor do I have? in reply to ejr-IA., 09-20-2005 19:36:21
I will check that tomorrow. Thanks every one
IaGary
09-20-2005 17:40:20
The paint is all off that area and not rusted.I even used my reading glasses and still saw nothing. |The ID tag on bell housing is also gone.
K.B.-826
09-20-2005 17:46:03
 Re: What motor do I have? in reply to IaGary, 09-20-2005 17:40:20
Gary, without those numbers, there's no telling what it is, aside from pulling the head and measuring the bore. Check that part number you posted to see if you typed it in correct, and I can search my CD's again.
IaGary
09-20-2005 17:53:38
 Re: What motor do I have? in reply to K.B.-826, 09-20-2005 17:46:03
The 9 could maybe be an 8.
IaGary
09-20-2005 17:24:53
Sorry its a gas and seems to plenty of power for a 560.
IaGary
09-20-2005 17:22:29
I just checked and i see the machined surface but their is no numbers at all. Surface may have been sanded off.
K.B.-826
09-20-2005 17:35:09
 Re: What motor do I have? in reply to IaGary, 09-20-2005 17:22:29
Painted over? I'm not kidding when I say the numbers are small and hard to find.
IaGary
09-20-2005 17:51:17
 Re: What motor do I have? in reply to K.B.-826, 09-20-2005 17:35:09
If you learn anything about that part no.let me know.I think thats all I have togo off of.
K.B.-826
09-20-2005 17:17:53
You did not say if it was a gas or a diesel. Describe your engine. If it's a diesel, does it have glow plugs? The first number you posted is a part number. Just searching my parts CD's quick, I could not find that number. The second number you gave is a cast date code, Aug. 30 1968, I think, which would be 5-10 years too late for a 560. The correct engines for a 560 are the C-263 gas or the D-282 diesel. Both use an almost identical block, and many different sizes of these engines were made and used throughout the years. They have the model number and serial number stamped very lightly on a small flat pad just to the rear of the oil filter base. It's very hard to see, so you'll have to clean that area if it's dirty. If it's a gas, look for C-221, C-263, C-291, or C-301. If it's a diesel, look for D-236, D-282, or D-301.
Nebraska Cowman
09-20-2005 16:12:47
M date code does not fit in 560 production
ken church
09-20-2005 15:28:35
I have a 560 (gas ) mine has a nuber stamped on the block just below where the firing order on the left side C263 18213 did not notice the number you have anynwhere but not saying that it would be different.... Ken c.
