hydraulic fluid question
hank n' tx
09-20-2005 16:02:42
i have a ih 340 diesel with the large hydraulic cylinder on the outside of tractor that operates the hydraulics. what type of fluid should i be useing? i have gl1-90wt in the tractor now which is also for the trans and rear end.ive noticed that it takes awhile for my hydraulics to start lifting after ive started the tractor. almost seems as if the fluid has to warm up before it will lift. what should i be useing? thanks for any help in advance
hank
old
09-20-2005 17:19:51
 Re: hydraulic fluid question in reply to hank n' tx, 09-20-2005 16:02:42
You should be useing something like HY-Tran or something equvalent
El Toro
09-20-2005 17:18:44
You should use hytran in your hydraulic system
90wt is for stick transmissions and differentials
and is too heavy for hydraulic use. It surprises
me it would lift at all with 90wt. My manual recommends that you use hytran for flushing the system. Some of the people that post on may have used something other than hytran. Hal
