C battery configuration.
Dave BN
09-20-2005 18:53:34
How should the terminals on my battery be arranged on my 1950 C? My 6V battery has the positive (ground) post to the front left, under the gas tank. The negative post is to the right rear, near the steering post. I'm thinking this is backwards from what it should be. I want to buy a battery box, but will I need to replace the battery also? Or will there be room to route cables under the lid of the box? Thank you. Dave.
gene bender
09-21-2005 04:12:19
 Re: C battery configuration. in reply to Dave BN, 09-20-2005 18:53:34
Just turn the batt so the posts are toward the front. The 625 amp batts will fit the box. The next size 6v batt is bigger thus wont fit. The box and batt is not fun installing on a C. I run the pos ground out with the neg and hook it to the rear stud on the gas tank. The original ground to the control housing can sometimes be rusty where it bolts to the frame and therefore not the best ground.
Wayne Swenson
09-21-2005 15:07:05
 Re: C battery configuration. in reply to gene bender, 09-21-2005 04:12:19
Get a longer grounding cable (2 gauge or larger) & ground it at the starter mounting bolt. That way the electricity has a direct path to the starter.
