F-20 Throttle slow to respond. Need help.
Mark J. in Mi.
09-21-2005 06:19:49
I posted this in an earlier message with no response and am trying again. When I advance or reduce the throttle is responds very slow. It take 10 to 15 sec for the RPM's to lower. It does respond better in advancing the throttle. I did rebuild the carb after I found a bee's nest in it. Is this a govenor spring problem? My F-12 responds immediatly. What could it be.
Thanks,
Mark
Mark J. in Mi.
09-21-2005 11:26:19
 Re: F-20 Throttle slow to respond. Need help. in reply to Mark J. in Mi., 09-21-2005 06:19:49
Thanks for the info.
Mark
Ron in Nebr
09-21-2005 08:13:34
Mine kinda does the same thing...when I first start it, it idles slow and smooth. Once I rev it up one time, it won't ever idle very slow again until I retard the timing on the mag kill switch when I'm shutting it off. When I reduce the throttle, the last several degrees of movement before slow idle have no effect on engine speed, although when I increase throttle it speeds up properly.
Nebraska Cowman
09-21-2005 07:30:46
kinda depends what you have. The original F20 goverenor was not a variable speed device and only goverened at high idle.
