300U problem, need help
300Randy
09-21-2005 08:06:10
Whats wrong with my 300U. I was having some overheating problems and have fixed that by cleaning the radiator out real good inside and out. The problem now is that after 10 minutes to even a half hour all of a sudden the engine starts running rough,rpms going up and down, coughing and sputtering and then dies. I have checked and I'm getting good gas flow to the carb. I let the tractor cool down then it starts fine again and will run good again for awhile. What could be the problem?
PAULIH300
09-21-2005 08:08:52
 Re: 300U problem, need help in reply to 300Randy, 09-21-2005 08:06:10
Coil.Sounds like its overheating.Feel it when its been run for a while.Should be hot if its bad.Could be a bum coil,a 6V coil used with 12V,or no resistor.
300Randy
09-21-2005 11:19:55
 Re: 300U problem, need help in reply to PAULIH300, 09-21-2005 08:08:52
I switched the tractor over to 12 volt about 3 years ago and added a ballast resistor. Can I get rid of that and just replace it with a 12 volt coil?
PAULIH300
09-21-2005 12:40:14
 Re: 300U problem, need help in reply to 300Randy, 09-21-2005 11:19:55
Make sure the 12V coil you get says "external resistor not required".
