ejr-IA and K.B.826 I found some numbers
IaGary
09-21-2005 08:56:00
Numbers on right side next to water C221 46743.If this is just a 221 cubic inch motor it sure is a powerful little thing.My stock 460 and MTA have less HP.I bought it at an auction about 4yrs ago for $900. Battery was dead and did not start at auction.Next day jumped it and drove it on the trailer.I have mowed all my hay with it since about 100acres a year using a 9ft conditioner. Run a 10"by 70ft auger all fall and still running fine. Lucky I guess.What was the motor normally put in? Thanks for help.
ejr-IA.
09-21-2005 12:38:45
 Re: ejr-IA and K.B.826 I found some numbers in reply to IaGary, 09-21-2005 08:56:00
May had a cracked orignal block used a 460 block with the 560 crank and pistons in it blocks will interchange.
El Toro
09-21-2005 09:30:44
Tractor data doesn't list the C221 for the 560, but it was probably the same as used in the 460. Hal
Nat
09-21-2005 11:56:37
 Re: ejr-IA and K.B.826 I found some numbers in reply to El Toro, 09-21-2005 09:30:44
That's correct. The 560 should have a C263.
I think the C221 and C263 block are the same, so this powerful little C221 could be a sleeper, maybe bored out, with the C263, or even C291 sleeves and pistons so the tractor has the horsepower of a true 560, 706, 756, or even a 766.
El Toro
09-21-2005 09:22:00
That was the engine used in the 460 gas version.
The 460D used the 236cid engine. The C221 was probably used in other tractors too. Hal
