weight on m
new farmall pul
09-21-2005 11:15:18
if i drain the fluid out of my m it has 13.6x38 6 ply armstrongs on 13 inch rear rims cast wheels, belly drawbar still has belly pump, motor is out of a 400 with hy pump behind the dist, what will this tractor weigh with a 250 lb driver, what gear will it pull in, 4th seems pretty fast driveing it around,
CNKS
09-21-2005 17:44:28
 Re: weight on m in reply to new farmall puller, 09-21-2005 11:15:18
An M weighs approximately 5000 lbs, with no fluid in the tires and no wheel weights, without operator, assuming a narrow front.
RustyFarmall
09-21-2005 14:04:44
If you drain the fluid put of your M it won't run very long. Did you mean the fluid in the tires?
Nebraska Cowman
09-21-2005 13:59:21
Div 1 here is 1st gear only
