560 Pump
DickD
09-21-2005 12:13:39
I have a friend that I am trying to help restore a 560 Diesel. He bought it with the pump bad,so we removed it to find the shaft was broken off on the end. Also the gear that drives the pump had several teeth broken off and it looked like something had caused it not to mesh correctly. Could there be a bearing or sleeve worn that would cause this? Any and all help would be greatly appreciated. Thank You
JakeF
09-22-2005 19:45:25
 Re: 560 Pump in reply to DickD, 09-21-2005 12:13:39
When the shaft broke it let the gear fall down into the timing cover and shear teeth off. When you pull the cover to replace the gear check the others and make sure you get all the broken teeth pieces removed. Hopefully you only ruined the one gear. Jake
El Toro
09-22-2005 08:38:32
Hi Dick, Here's a company that may be able to rebuild your old pump. Hal
PS: toll free number 1-800-553-1821
http://mylexinternational.com/injectionpumps.htm
ejr-IA.
09-21-2005 12:26:56
The diesel pump head siezed get a different pump ,gear and shaft.
