Timing gears for 350U
Mark and Anik
09-21-2005 20:41:58
Looks like I blew the timing gears on my International 350U. Does anyone know a good (cheap) source for these? I've got to get this thing in order before the snow flies and I'm snowbound. Thanks
RAS
09-22-2005 10:36:36
 Re: Timing gears for 350U in reply to Mark and Anik, 09-21-2005 20:41:58
Cam gear 6664DB from Case/IH 139.40.
El Toro
09-22-2005 06:24:54
I would agree with Bob M on new gears. The timing gear is probably a press fit and would be easier to pull the camshaft and use a hydraulic
press to remove and install the new gear. Hal
PS: For parts at C&G email juda@cngco.com or
brooklyn@cngco.com
Bob M
09-22-2005 06:34:49
 Re: Timing gears for 350U in reply to El Toro, 09-22-2005 06:24:54
Hal -
The cam gear is keyed to the camshaft extension with a woodruff key - a half-height, fine thread nut clamps the gear hub to the shaft.
My experience is the cam gear slides off easily after removing the hub nut - no need to remove the camshaft from the engine! ...Bob
El Toro
09-22-2005 08:08:06
 Re: Timing gears for 350U in reply to Bob M, 09-22-2005 06:34:49
Hi Bob, Thanks for the info. Everything is different, nothing stays the same. Hal
Bob M
09-22-2005 05:39:44
Carter & Gruenenwald (www.cngco.com) stocks new gears. They're not exactly cheap - I think I paid about $160 for a cam gear several years ago. But delivery is quick and parts are factory fresh.
Note: The 350's live pump places a heavy load on the cam drive gear - I'd be hesitant to install a used gear here! OTOH the idler and governor drive gears carry essentially no load - installing used parts here should be OK.
Unreserved dick
09-21-2005 23:44:33
You're probably going to end up talking to a salvage dealer. The link below gives a pretty good listing of those in the US. For what you probably need I'd suggest JP Tractor Salvage in Missouri - I've had pretty good luck with them.
iester
09-21-2005 22:04:45
Timing Gears...dist..need more info
