no hyd pressure on 560
super red
09-22-2005 18:34:41
I put a new ta in my 560 and when I was done the hyd dont work it worked before I taken it apart . I split it again to check the o ring on the siphon tube it was good . the fast hitch and the power steering dont work either . the only thing I can think of is a air lock . I am open to any ideas.
ejr-IA.
09-23-2005 14:03:12
 Re: no hyd pressure on 560 in reply to super red, 09-22-2005 18:34:41
Had that happen on my 460 when I had the center section out.Theirs a suction pipe between the pump and where it goes over to the filter it has a gaskett or o ring you might check that.Also you need a good seal on the plate where you put the hyd. filter in.I ended up putting a extra gallon or more in the rear end to get it primed.
super red
09-23-2005 14:46:45
 Re: no hyd pressure on 560 in reply to ejr-IA., 09-23-2005 14:03:12
thanks I will give it a try tomorrow . I put a new seal on the tube . it must be a air lock somewhere I will put extra oil in and see what happens
