All 350 utility owner's
iester
09-22-2005 19:24:25
What is your oil pressure at idle and at full throttle? Thanks Lester
Duner Wi
09-23-2005 17:30:15
 Re: All 350 utility owner's in reply to iester, 09-22-2005 19:24:25
My 350U hot with 10W30 oil runs 20 lbs at idle and 60 lbs.at full throttle. Cold it is 60 lbs. idle and same at high RPM. Has not changed in 30 years. Has the I-H gauge.
mark k
09-22-2005 19:54:07
Hello,
I have a propane 350 and at idle it runs 40 above idle it goes to about 55-60. When I first got the tractor it had not ran in several years when it started I thought the gauge was broken (used to a VAC Case 12 psi) but the gauge was correct. Mark
iester
09-22-2005 20:08:57
 Re: All 350 utility owner's in reply to mark k, 09-22-2005 19:54:07
I'm useing a automotive type gauge does that make a difference? I though pressure would be the same.
PAULIH300
09-22-2005 19:29:01
My 300U stays at 3/4 gauge no matter the engine speed,and I have 15/40 diesel oil in it.
iester
09-22-2005 19:42:04
 Re: All 350 utility owner's in reply to PAULIH300, 09-22-2005 19:29:01
Hey Paul,I live in Ky.I refilled with 10w30 and only get about 18# pressure low idle warm and 60# at full throttle.Should I change oil weight? Any thought's?
Nat
09-23-2005 06:44:26
 Re: All 350 utility owner's in reply to iester, 09-22-2005 19:42:04
Sounds fine to me. I think you're getting worked up over nothing.
iester
09-22-2005 19:44:40
Forgot it's a gasser.
Janicholson
09-23-2005 14:35:04
 Re: All 350 utility owner's in reply to iester, 09-22-2005 19:44:40
Multi wt. oil is exceptional stuff and just fine for your unit. One reason the automtive ind. uses idiot lights is that indicated oil pressure may be 5 to 8 PSI at idle, warmed up, in new cars!!!
My 350 runs 20 at idle operating temp, and 55 at full throttle. H about the same MD 25 and 60.
Its Cool dont worry,
JimN
