can't shift into road gear
Don Wells
09-24-2005 14:02:15
On my 350 Utility I cant shift into road gear. It will barley start to go in but as soon as you let the clutch out it pops back into netural. What do I need to do to repair and will it be costly.
Andrew Z
09-24-2005 17:24:58
 Re: can't shift into road gear in reply to Don Wells, 09-24-2005 14:02:15
Sounds Like you need forks and rails or at least to replace the detent ball and spring. Its not a real hard project. The parts should not be to bad. Andrew
