Whats a good weight for oil to use year round
lekander883
09-25-2005 18:21:19
Anyone have good results from using a certain weight of oil year round. Or recommend a certain weight in my 1945 farmall h Thanks
sammy the RED
09-27-2005 09:35:19
 Re: Whats a good weight for oil to use year round in reply to lekander883, 09-25-2005 18:21:19
10w30 for year around.
I use 30 wt. for the summer working tractors.
CNKS
09-26-2005 06:27:06
15W40 is fine. If you run it in below freezing weather you may find that 10W30 makes it a little easier to start. If you live in a warm climate, ie, south Texas, southern CA, or the SE US, straight 30W (detergent) is ok.
Dellbertt
09-25-2005 21:32:21
About 2 lbs. per qt.
Steven@AZ
09-25-2005 19:32:24
Mobil Delvac 5W-40 full synthetic.
old
09-25-2005 19:14:34
Sort of depends on where you are. I use 30W in the winter and let them run 10-15 minutes before working them. In the summer so of my tractors have 50W in them.
riverbend
09-25-2005 18:32:00
I use 10W40 in my H.
