to buy or not to buy
58 cub
09-26-2005 09:54:26
I am looking to buy a 58 farmall cub. It needs some carb. work the seller says. It has 2 new front tires, new rings, and has had the top end rebuilt. Was told that runs good but the carb. loads up and then the tractor stalls out. It comes with disc, plow, road blade, and cultivators. Seller is asking $1000. I know I will need to do some work on it, but if some one could give me so input on whether it is a good buy or not. I appreciate any input alot.
thanks, 58 cub
evielboweviel
09-26-2005 17:10:25
 Re: to buy or not to buy in reply to 58 cub, 09-26-2005 09:54:26
if you don't buy it then where is it located at??
Ron
Dave H (MI)
09-26-2005 12:12:20
Not likely you would lose anything, especially with all the extras. Carb is nothing. You can buy a kit to rebuild and people here will help you with anything that comes up.
RustyFarmall
09-26-2005 10:09:42
You might try offering $800 because of the carb needing work but even at $1,000 it isn't a bad deal. The carb isn't a big deal, I may even have a new aftermarket carb for it.
old
09-26-2005 10:05:32
Cubs in my area with all that stuff with it would go for around $2000-3000. As far as the carb you can buy a new/rebuilt one for around $150-200 so you would stil only have $1200 in a tractor worth around $2500. Sounds like a good buy to me unless the rear tires are bad and the sheet metal is bad.
Dion
09-26-2005 10:04:58
I have bought running cubs for $500-800. All needed a little work but all ran and drove.
Jonathan Brown
09-26-2005 10:18:55
 Re: to buy or not to buy in reply to Dion, 09-26-2005 10:04:58
Why put an after market Carb on it when you can go the the Case/IH dealer and buy a complete carb kit for half the price of the after market carb?
RustyFarmall
09-26-2005 12:41:34
 Re: to buy or not to buy in reply to Jonathan Brown, 09-26-2005 10:18:55
Have you checked the price of a kit from Case-IH lately? It would be about as cheap to buy a reman carb.
Jonathan Brown
09-26-2005 13:06:38
 Re: to buy or not to buy in reply to RustyFarmall, 09-26-2005 12:41:34
I just put a complete kit in a b for abour 70 dollars. I have not put one in the cub yet. but there are aftermarket places for carb kits as well that are cheaper that 150 dollars such as branson enterprises who list a kit for 24 dollars
farmallman
09-26-2005 11:12:29
the only reason I would do it is b/c it is cheaper....
