gear ratios and horsepower
robertw
09-26-2005 12:42:02
What is the difference between the gear ratios in a Farmall H and Farmall Super H? I know 2nd, 3rd and 4th are faster in the Super H, but was wondering how 1st gear compares in the two. Also, what is the horsepower in the H and Super H?
DWV
09-26-2005 18:36:36
 Re: gear ratios and horsepower in reply to robertw, 09-26-2005 12:42:02
With same size tires and turning the same RPM
the speeds are exactly the same in first and fifth.Both offered a low low first gear the same ratio.Only H offered a non standard fourth gear called high speed fourth.The tooth count for 2,3 and 4 listing driving gear first. H-2 28&42, H-3
31&39, H-4 35&35, H high speed 4 41&29. SH-2 29&41,SH-3 34&36, SH-4 39&31.Regular first both
23&47, Low low both 17&53.Pinion,ring gear,constant mesh and bull gears same ratio.This is on regular row crops.
Haas
09-26-2005 13:55:02
From Fay's data book
Gear H Super H 1st 2 5/8 mph 2 5/8 mph
2nd 3 mph 3 3/4 mph
3rd 4 1/4 mph 5 mph
4th 5 3/8 mph 6 5/8 mph
5th 15 5/8 mph 16 1/4 mph
Belt HP 27.9 34.61
Speeds are with 10X38 tires for the H and 11X38 tires for the Super H. Format of table does not come through to the forum. I think you can make it out though.
CNKS
09-26-2005 17:19:17
 Re: gear ratios and horsepower in reply to Haas, 09-26-2005 13:55:02
Not a great deal of difference, but these are out of the H/Super H Operators manuals with the same tire size you list:
H Super H
1st 2 1/2 2 5/8
2nd 3 3/8 3 3/4
3rd 4 1/8 5
4th 5 1/8 6 5/8
5th 15 5/8 16 1/4
Drawbar HP -- (not in manuals) 25.5/31
It is very easy to misplace or miscopy numbers when writing or publishing.
Gatz
09-27-2005 09:00:46
 Posting TableTest in reply to CNKS, 09-26-2005 17:19:17
just tryin something out...if it works, I'll repost new, Gatz
From Haas's post of 9-26-05
       "H"       "Super H"
1st 2 1/2 2 5/8
2nd 3 3/8 3 3/4
3rd 4 1/8 5
4th 5 1/8 6 5/8
5th 15 5/8 16 1/4
CNKS
09-27-2005 18:17:30
 Re: Posting TableTest in reply to Gatz, 09-27-2005 09:00:46
That's nice -- I can do that too, just too lazy.
gatz
09-27-2005 09:22:01
text
end
gatz
09-27-2005 09:31:07
 Re: Posting TableTest in reply to gatz, 09-27-2005 09:22:01
table
end table
