h carb.
virgils
09-26-2005 15:18:15
I have a 6212DB carb. on my 1942 H. I am wondering if it is a all-fuel or gas carb..
RustyFarmall
09-26-2005 21:34:22
 Re: h carb. in reply to virgils, 09-26-2005 15:18:15
Doesn't really make any difference. I have had both gas and distillate carbs apart, and they are the same inside. Originally there may have been a difference in the metering tube, but the distillate carbs most likely were changed over when that fuel became obsolete.
CNKS
09-26-2005 17:03:34
Dunno, 6212 is the number of the fuel bowl, only, they do not differ between carbs. There should be a tag on it somewhere that has the number. 45108 is dist/kero, 50981 is gas only. The 45108 should have a wing nut for a drain, 50981 will just have a plug -- I don't think that is the final answer though, as my dad had a gas only H, the carb had the wing nut.
