Loose Swartz Wide Front End (for 400D)
Farmall Frank
09-26-2005 16:29:18
I notice a lot of movement in the steering linkages on my Swartz. It occurs at each connection. The wheel bearings are snug, but from there on back, a lot of play.
Is there a way to tighten up those linkages, or do the ball joints (my term) need to be replaced? If so, where can I get parts?
Thanks.
Billde
09-27-2005 08:21:50
 Re: Loose Swartz Wide Front End (for 400D) in reply to Farmall Frank, 09-26-2005 16:29:18
A&I Products still makes the Swartz front ends, also repair parts. They have a website.
ET
09-27-2005 06:33:38
The tie rod end can be ajusted by removing a cotter key and screwing the cap in a little deeper.
Nat
09-27-2005 06:01:02
You'll have better luck with SCHWARTZ in your search. The Swartz is from the movie "Spaceballs."
Once the tie rod ends are worn, there's not really much you can do but replace them. Schwartz is still around, so you can still buy the original tie rod ends. WARNING: It won't be cheap, and there is no cheap way out, no cheaper alternative for these tie rod ends.
riverbend
09-26-2005 18:31:02
I have some slop in the tie rods on my Schwartz (sp?) front end. It looks like the joints are adjustable, but I have not taken the time to tighten them up.
