Farmall H Throttle Butterfly?
John in Ct
09-26-2005 18:49:33
What is the correct number for the brass Throttle Butterfly on a Farmall H? Is it 11 or 9 (6 upside down). Also, after you install the Throttle Butterfly, when the butterfly is fully closed, is the side that is facing up suppose to have the number on it? Thanks!!
RustyFarmall
09-26-2005 21:27:12
 Re: Farmall H Throttle Butterfly? in reply to John in Ct, 09-26-2005 18:49:33
I just recently had two different H carbs apart, I know for sure that the number goes up, and I think the number is 6, or 9. I'll go out to the shop in the morning and look.
RustyFarmall
09-27-2005 05:21:43
 Re: Farmall H Throttle Butterfly? in reply to RustyFarmall, 09-26-2005 21:27:12
OK, just came in from the shop, 2 carburetors I looked at, one has 11, the other has 9. The number is on the top.
John in Ct
09-27-2005 06:09:46
 Re: Farmall H Throttle Butterfly? in reply to RustyFarmall, 09-27-2005 05:21:43
Thanks Rusty!!
