Body filler prep on my H's Auxilliary Fuel Tank??
Tanner Clark
09-27-2005 11:31:01
Folks,
I have been preping and priming a lot of my pieces to the tractor recently. When I stripped my auxilliary fuel tank down to bare metal, I noticed there were a number of little pin holes in it. I have not intention of running fuel through this once the project is complete, but I need to patch these holes up for the paint job. What brands or materials do you reccomend I use to do this, bondo, etc. I assume I shoudln't use JB weld, b/c I need to sand and prep the area again for primer and paint. Any hints?
Thanks.
CNKS
09-27-2005 18:10:51
 Re: Body filler prep on my H's Auxilliary Fuel Tan in reply to Tanner Clark, 09-27-2005 11:31:01
JB Weld is my primary body filler for dents more than about 1/16-1/8 inch deep, should work fine on your pinholes, if you are sure you won't use the tank -- but, I would rather fix it right or see if I can find a replacement tank. The JB Weld gets sanded and covered with body filler -- repair is invisible when painted, and the body filler is not thick enough to crack later.
El Toro
09-27-2005 14:17:45
You can solder those pin holes shut with a big soldering iron. Don't use a torch. Hal
RustyFarmall
09-27-2005 13:14:17
Any auto body filler should be just fine. JB weld can be sanded, prepped, primed, whatever, just like any other epoxy type filler.
Red Dave
09-27-2005 11:42:35
I'd get some of the epoxy that's made for gas tank repairs and plug the holes, then finish with the body filler to smooth it off for painting.
