C135 Engine
Tweeter
09-27-2005 12:21:27
I have to change the oil pan gasket on my C135 engine and I will also be changing the oil then. What oil filter do I use and what is the number? What weight oil do I use? Anything that I should should know before changing the oil pan gasket?
El Toro
09-27-2005 13:29:29
 Re: C135 Engine in reply to Tweeter, 09-27-2005 12:21:27
Try wixfilters.com. Hal
Tweeter
09-27-2005 17:49:19
 Re: C135 Engine in reply to El Toro, 09-27-2005 13:29:29
Is the filter a spin on or a cartridge?
El Toro
09-28-2005 04:31:26
 Re: C135 Engine in reply to Tweeter, 09-27-2005 17:49:19
What tractor is this? Some of the tractors used a spin on filter and some used a cartridge. The cartridge cannister would have a removable top. You would need to look at your filter on your engine. There should be a number on the old filter that your local auto parts store can cross reference. Hal
