Cityboy-McCoy
09-27-2005 17:14:11
Boys, the carb on my Super A has about got me whipped. Bought this Super A tractor about a month ago and it was running fine. Then, it started running rich (missing and black smoke). Got worse very quickly and would quit. Carb flooded and dripping. I took the carb down, (it was dirty with rusty corrosion) cleaned it good by letting it soak in carb cleaner, cleaned all jets and passages, blew them out, etc, put it back on. Had to clean the soot off the plugs and she fired right up and ran right smooth. I thought I was a genius. Then, it started the same thing again within 30 minutes. Sometimes I could clear it up by tapping on the bottom of the bowl - sometimes not. If it was running fine, it seemed like it would immediately run rich and rough the minute I drove the tractor 6 feet. Went and bought a kit. In the process I learned it previously had the wrong bowl gasket. Bead-blasted the float chamber, rebuilt it again and set the float to specs. Made sure the float was good by floating it in a bucket of water for 2 hours. Made sure the float could not hang on the bowl gasket. Put it all together - clean as a whistle - with the correct initial settings, cleaned off the plugs, fired her up and she ran as smooth as an Eldorado Cadillac with a spare tire on the back. Thought I was a genius, again. Ran fine for three days. Now, it's doing the same thing again - missing, black smoke and flooding to the point of dripping on the ground and quitting. No water in the gas, have a fuel filter good for non-pressure applications. I ain't no Genius! Do these Zenith carbs just sometimes go bad? What am I missing here? Thanks, Mike
