off-timing
Levi Keech
09-27-2005 18:44:21
How do you check for off-timing?
PAULIH300
09-28-2005 02:44:34
 Re: off-timing in reply to Levi Keech, 09-27-2005 18:44:21
I actually time the engine by "ear".With the engine at low idle,slowly rotate the distributor one way and then the other,wherever the engine runs the smoothest and fastest is where I leave it.Check to make sure the engine doesnt fight the starter to crank...this would mean you have it too far advanced.Most of the time,when I do this,I can check it with a timing light,and its usually either right on,or off by only a couple degrees.
the tractor vet
09-27-2005 19:29:38
Bring it up to TDC on the compression stroke on # 1 and check where the rotor is pointing then i check it with a timming lite.
