H carb Throttle shaft bushing?
John in Ct
09-28-2005 15:51:00
I got my bushing out and ordered up one. What is a good way to install it without hurting it and if it needs to be reamed, to what diameter? Thanks!!
riverbend
09-28-2005 19:09:08
 Re: H carb Throttle shaft bushing? in reply to John in Ct, 09-28-2005 15:51:00
The bushing was easy to put in. I think I just used a C clamp. Once it was installed, it was tight on the throttle shaft, and not having a reamer, I used a 1/4" drill. If you have access to more sophisticated machine tools, you might check the shaft and add a few thousandths. In any case, checking the shaft diameter is a good idea, as my memeory might not be perfect.
rj1939
10-02-2005 05:54:23
 Re: H carb Throttle shaft bushing? in reply to riverbend, 09-28-2005 19:09:08
I size them before I install them, put the bushing in a drill press and use sandpaper wrapped around a dowel rod to polish it out to size.
