Running water Temp?
jester
09-28-2005 18:51:55
What should water temp be at working/running degrees be? it's a 350 4 cylinder gas ih tractor
El Toro
09-28-2005 19:06:50
 Re: Running water Temp? in reply to jester, 09-28-2005 18:51:55
It depends on the temperature of your thermostat.
Usually from 180 to 195 degrees. Hal
iester
09-28-2005 19:18:46
 Re: Running water Temp? in reply to El Toro, 09-28-2005 19:06:50
Thanks,I used part number from book.All it said 165-195 degrees T-stat
El Toro
09-29-2005 04:24:03
 Re: Running water Temp? in reply to iester, 09-28-2005 19:18:46
The hotter the engine runs the better it will
run, but you don't want it too high when you're
using it for heavy work in a very hot environment.
The same would be for your car and truck until you hook a heavy trailer load onto them because you're really working them. Hal
