180 degrees?
iester
09-28-2005 19:49:22
Should I Block Radiator to maintain this temp,It runs cool?
jfp
09-30-2005 03:02:33
 Re: 180 degrees? in reply to iester, 09-28-2005 19:49:22
180 degrees is perfect in a gas engine. Leave it the way it is.
El Toro
09-29-2005 15:13:38
I would pull that thermostat and place in a pan of water and heat it to see what temp it's opening at. I would put a 195 degree in for the winter. You need to get the engine temp up so the cylinders aren't loaded with fuel and
should be operated under load so as to raise the temp quickly. Hal
Jim Allen
09-29-2005 14:02:57
It's not as immediately harmful to run an engine too cold as it might be to run it too hot, but you get poor performance, fuel washing down the cylinder walls (gas or diesel) and diluting the oil. Diesels, especially the low compression ones, run like crap when they are too cold. My 826 sure does and I think the t-stat is gone because it takes forever to warm up. You want it to warm up as quickly as possible and stay at operating temp.
CNKS
09-29-2005 07:44:00
In the post below, you said 350? The H--350 engine warms up very slowly. Unless you are moving snow in the winter or something, it is not a concern. Also, your gauge could be wrong.
F-Dean
09-29-2005 06:26:43
Check the owners manual. The W-30 owner's manual recomends blocking an outlet if you do not ren a thermostat.
Do I have Rabies
09-28-2005 20:42:56
Yes
the tractor vet
09-28-2005 20:05:18
What tractor we talken about?????
iester
09-29-2005 15:05:44
 Re: 180 degrees? in reply to the tractor vet, 09-28-2005 20:05:18
It's a 350 utility gas.It has new t-stat and gauges.
El Toro
09-29-2005 15:21:28
 Re: 180 degrees? in reply to iester, 09-29-2005 15:05:44
Here's a toll free number for Phillips & Temro
that sell engine coolant & block heaters. Hal
1-800-328-6108
Illinois Boy
09-29-2005 09:08:41
I was wondering the same thing - is it diesel or gas?
